Auteur Sujet: USB Switch pour RCD510 et RCD310  (Lu 27561 fois)
Hors ligne nonofou06
  • Nice
Qui a déjà installé ça ?  :quoi:
Peut on lire des mp3 sur clef usb ?
http://www.ebay.com/itm/300868090556
« Réponse #1 le: 05/28/13 »
C'est vrai que ça m'a l'air bien foutu.
Quid d'un éventuel codage...
Hors ligne Loucks
  • Country: re
  • Saint-Denis
« Réponse #2 le: 05/28/13 »
Hmm.. intéressant. Il faudrait pouvoir voir comment il se branche à l'arrière du RCD.
Car la petite phrase de l'annonce : "Some additional effort/change may be required"
Me laisse un peu perplexe au niveau du branchement.
Après, pour ceux qui possède le RCD 510, une carte SD est suffisante  :siffle:
« Réponse #3 le: 05/28/13 »
D'abord, l'anglais du chinois n'est pas top, switch est inapproprié, switch c'est interrupteur, socket c'est prise  ;)
Q: Hello Warrior, I'm interested in purchasing an USB interface for my RCD300 on VW Golf 5 2004, I understan this one should theoretically work? I have 2 available 12 pins in the back of the RCD, maybe I should upload a... Continue reading
A: The usb cable is round one. if your interface is not round, you may not install it. You can send me the photo for the double-check Thanks
 Apr 29, 2013
Q: I'm sorry that I don't get what you meant on your last reply. So what do you mean with usb interface? Do you sell that item too? I hope i buy that item from you. Thx
A: yes, as long as your rcd has usb interface, you can connect it with this swtich Thanks
 Apr 25, 2013
Q: I have no MDI on my golf 6. It just came with RCD310, so will this usb cable will work without MDI? Do I need to install something to use this usb cable or it just work as plug and play device to RCD310? Sorry for asking, i... Continue reading
A: it dose not need MDI interface. It requires USB interface. The is round interface. If you have that interface, you can use it Thanks
 Apr 21, 2013
Q: Hi there, Where should i install the usb port? In the armrest or on the dashboard near the cigar lighter? Thx for your kind respond
A: you'd better check it with your local vw specilist. Most of them choose the dashboard near the cigar lighte thanks
Question codage, je ne vois pas ce qu'il y aurait à coder, c'est juste un cable allonge avec une prise usb :quoi:
Hors ligne yoshisdown
« Réponse #4 le: 05/28/13 »
Sur d autres annonces identiques on voit le câble.
Mais c est vrai que ça serait une bonne alternative a la prise auxiliaire, ça permettrait de recharger l iphone, d avoir les titres de la musique sur l odb peut être, pour un coût très faible!
Hors ligne Loucks
  • Country: re
  • Saint-Denis
« Réponse #5 le: 05/28/13 »
Pas sur qu'il va remplacer le MDI juste avec un cable  :gratte:
Hors ligne BOIRSANSSOIF
« Réponse #6 le: 05/28/13 »
Comme dit précédemment ,la carte SD suffit largement ,pourqu'oi compliquer. :coucou:
« Réponse #7 le: 05/28/13 »
Peut être pour les RCD310... Moi je serai vraiment très intéressé si cela convient.. ! Mais où peut on le brancher ...?? :gratte:
Hors ligne Beone titane
« Réponse #8 le: 05/28/13 »
Placer la connexion USB sur l'emplacement des interrupteurs VW est bien...mais je ne comprends pas comment le câble se connecte sur le RCD 310 et encore mois sur un boitier Media in.
« Réponse #9 le: 05/28/13 »
Sur aliexpress français j'ai trouvé des photos http://fr.aliexpress.com/item/VW-GOLF-MK5-MK6-RCD510-USB/520678535.html
Les deux connecteurs du cable allonge
Et l'arrière du RCD510 ????
Il existe le même genre de prise pour l'entrée Aux-in soit séparée, soit combinée avec la prise USB
Et ça c'est le numéro de série original VW  :siffle:
Sur le site de nonofou09 (warrior_age), il y a deux autres "RCD510" contruits par Delphi (les pompes haute pression, les clim  :gratte: ) avec cette prise USB et l'entrée caméra de recul
avec ces numéros:  5ND035195, 5ND035190A et 56D035190
VW Genuine Radio RCD510 USB+Reverse Image New W Code Golf, Alors original ou copie? à vos ETKA  ;)
« Réponse #10 le: 05/29/13 »
Donc ca ne serait pas compatible Rcd310 mais uniquement Rcd510... Enfin si j'ai bien compris.
« Réponse #11 le: 05/29/13 »
Sauf si il y a la même prise derrière un rcd310.
« Réponse #12 le: 05/29/13 »
J ai demandé au vendeur pour savoir si on pouvoait brancher un iphone afin d écouter la musique de celui ci dessus mais il n a pas été capable de me répondre...
Hors ligne Onay974
  • Country: re
« Réponse #13 le: 05/30/13 »
qui veut se lancer pour l'acheter et essayer?
Hors ligne DrifteurFou
  • Liège
« Réponse #14 le: 05/30/13 »
Fort intéressant  :jap: Et avec un RNS 510 ?
Maintenant il faut voir comment ça fonctionne. Car si c'est comme lorsqu'on branche un GSM via prise AUX ( tout est géré par le téléphone, la voiture ne servant que de hauts parleurs), c'est beaucoup moins intéressant .
Mais si c'est un équivalent du Media In ( ce qui serait fort étonnant), alors bingo  :10sur10:
Un cobaye ?  :siffle:
Présentation de ma Golf 6 1.4 TSI 160 DSG7 Shark Blue
http://www.golf6forum.fr/index.php?topic=14363.0
