Auteur Sujet: Enceintes arrière absentes.  (Lu 26542 fois)
Hors ligne kythi
  • Aix-en-provence
« Réponse #15 le: 12/31/12 »
dit moi exactement où est l'étiquette je vais aller jeter un oeil.
Hors ligne seb60
« Réponse #16 le: 12/31/12 »
tu souleve la moquette plancher du coffre pour acceder a la roue de secours elle sera collée sur la tole a ta gauche .
Hors ligne kythi
  • Aix-en-provence
« Réponse #17 le: 12/31/12 »
Donc voici l'étiquette dans le coffre :
Hors ligne seb60
« Réponse #18 le: 12/31/12 »
tu tapes tes codes sur ce site
igorweb.org/equidec/Default.aspx
les codes commence sur l etiquette a partir de boa.....
Hors ligne kythi
  • Aix-en-provence
« Réponse #19 le: 12/31/12 »
Donc résultat :
B0A = Component parts set without country-specific design requirement
CV0 = Alloy wheels 7J x 17
G1A = 6-speed automatic transmission
H6L = Tires 225/45 R17 91W
J0N = Battery 330 A (61 Ah)
D91 = 4-cyl. turbo diesel engine 2.0 l/103 kW (4V) TDI common rail; Base engine: TG3/ TJ3/TU3/TU4/TL4/TP4/TM3/TW3/TR4/TS1/TN5
1AT = Electronic stabilization program (ESP)
1GB = Front shock absorption for rough-road design
1MV = Leather steering wheel
1NL = Covers for alloy wheels
5RQ = Right exterior mirror: convex
5SL = Left exterior mirror: aspherical
TG3 = 4-cylinder diesel engine 2.0 L unit 03L.A
0BD = Rear stabilizer
3U1 = Foldable trunk cover
QG1 = Service interval prolongation
8VA = Without clock (out of instrument insert)
8GU = Alternator 140 A
8ZG = Antenna for AM/FM reception
1KD = Disc brakes, rear
1ZE = Disc brakes, front (Geomet D)
G07 = Front shock absorption
7MG = Emission standard EU5
0Y1 = Standard climatic zones
4UP = Drivers and front passenger air bag with knee air bag and front passenger air bag deactivation
4X3 = Side air bag front with curtain air bag
4R4 = Power windows with comfort operation andcircuit breaker
4K3 = Radio remote controlled central locking operated from inside and safe securing
N0R = Seat covering
5MJ = Decorative inserts
8RE = 4 speakers (passive)
2JD = Sports bumpers
E0A = No special edition
0AD = Front stabilizer
2VA = Nameplate set "GTI 16V Edition" (without model designation)
2G5 = Filler neck module 1 without insert
1JA = Rear shock absorption, basic design 1
L14 = Suspension range 14 installation control only, no requirement forecast
0YB = Weight range 2 installation control only, no requirement forecast
Edit : certain code mal tapé. (no found)
Hors ligne kythi
  • Aix-en-provence
« Réponse #20 le: 12/31/12 »
Y marque 8RE = 4 haut-parleurs (passive)
Putain ! faut que je l'ai installe à l'arrière :'(
Hors ligne seb60
« Réponse #21 le: 12/31/12 »
Tu a 4hp donc inutile de te prendre la tete !
l ancien proprio a peut etre essayer de monter les hp en pensant que c etait precablé.
Donc tu n a pas les enceintes ar...
faut tirer les cables et modifier le codage.
Hors ligne kythi
  • Aix-en-provence
« Réponse #22 le: 12/31/12 »
Tirer les câbles -_-" sa veut dire tout démonter ... Y'a un tuto sur le forum a ta connaissance ?
Merci de ton aide en tout cas !  :copain:
Hors ligne seb60
« Réponse #23 le: 12/31/12 »
Conseil d ami
demande a vw sanary sur mer pourquoi ils ont mis des parechocs renforcé sur ta caisse
y a du avoir des travaux de carrosserie....
surprise surprise
Hors ligne seb60
« Réponse #24 le: 12/31/12 »
Je crois que oui mais perso je ne l ai pas fait car tout demonter = rossignol dans toute la voiture aprés . tu va te retrouver dans une peugeot tellement ca grincera de partout..
Hors ligne kythi
  • Aix-en-provence
« Réponse #25 le: 12/31/12 »
Comment vois-tu qu'ils ont remplacé les parechocs "renforcé" ?
Oui je veux pas tout démonter à cause de sa...
Hors ligne seb60
« Réponse #26 le: 12/31/12 »
la 2eme etiquette en dessous avec code rajouté 2k2 !
Hors ligne kythi
  • Aix-en-provence
« Réponse #27 le: 12/31/12 »
Ok je vais les appeler de suite eux ! putain  :quoi:
Hors ligne seb60
« Réponse #28 le: 12/31/12 »
Tiens  :coucou: moi au courant
Hors ligne kythi
  • Aix-en-provence
« Réponse #29 le: 12/31/12 »
Oui c'est fermé entre midi et deux mais j'appel dans l'après-midi.
