Auteur Sujet: VAG COM et Defaults Codes  (Lu 4809 fois)
Hors ligne maxou28
  • Eure et Loir
  • 2.0 TDI 110 BVM
« le: 07/28/13 »
J'ai acquis récemment une Golf VI 2.0 TDI CONFORTLINE, possédant un cable VAG, j'ai lancé un AUTO SCAN et voici le résultat de celui ci :
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 11.11.3 Data version: 20120401
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Friday,26,July,2013,15:55:20:32264
VIN: WVWZZZ1KZ9P441209 License Plate:
Mileage: Repair Order:
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 MC HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 6179
Revision: 13H01--- Serial number:
Coding: 0000071
Shop #: WSC 06280 995 93663
VCID: 72E1C4116DB4009
No fault code found.
Readiness: 0 0 0 0 0
VCDS
Self-Diagnosis Log
Page 2
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0000257
Shop #: WSC 00028 028 00001
VCID: 76E9F80101DC1C9
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 AJ HW: 5K0 907 044 AJ
Component: Climatronic 130 0303
Revision: 00002001
Coding: 0000000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW36.rod
VCID: 73EFC115DAAE091
VCDS
Self-Diagnosis Log
Page 3
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 HW: 1K0 937 084
Component: BCM PQ35 B 020 0358
Revision: 00020000
Coding: 40180A3A98251AC040080080140000E445510088536D8960648000000000
VCID: EBDF59750A9E511
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 25110 21 0501
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 081208 05 54 0402
Coding: 0330AD
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 5
Mileage: 66507 km
Time Indication: 0
Date: 2112.14.08
Time: 06:02:04
Freeze Frame:
Term 15 On
Voltage: 10.00 V
ON
ON
Term 50 On
OFF
OFF
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 HW: 5K0 919 475
Component: PARKHILFE 8K H07 0002
Revision: -------- Serial number: 60640832509931
Coding: 100001
VCID: F3EF411552AE891
VCDS
Self-Diagnosis Log
Page 4
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 022 0507
Serial number: 003C2D06JUML
Coding: 00003135
Shop #: WSC 00028 028 00011
ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: F7F775054ED6E51
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 134F4545ZZZZZZZZZZZZ
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 32661244ZZZZZZZZZZZZ
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 2C22061BZZZZZZZZZZZZ
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 22050267ZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 855 0111
Coding: 0000532
VCID: 78F5F6390BC86A9
Subsystem 1 - Part No: 3C8 959 537 B
Component: E221__MFL-TAP H4ÿ 0021
Coding: 00000226
Shop #: WSC 00000
VCDS
Self-Diagnosis Log
Page 5
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 870 C HW: 5K0 920 870 C
Component: KOMBI H21 0029
Serial number: 00000000000000
Coding: 170B00
Shop #: WSC 00028 028 00025
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2D5B176D7C0A1F1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 251108F2001794
Coding: E9A07F06000202000002
VCID: 377735054656A51
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Component: IMMO H21 0029
Serial number:
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1K0 959 701 AG HW: 1K0 959 701 AG
Component: Tuer-SG 008 2033
Coding: 0004278
VCID: 73EFC11512AE091
VCDS
Self-Diagnosis Log
Page 6
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 69 2501
Revision: 00H15000
VCID: 2C5D1A698F10169
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1K0 959 702 AG HW: 1K0 959 702 AG
Coding: 0004534
VCID: 74EDC20917A00E9
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 012 0029
Revision: 00000000 Serial number: VWZ1Z2H5877753
Coding: 0500040004
VCID: 65CBAF4D6C7AE71
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 128
Mileage: 73469 km
Time Indication: 0
Date: 2115.14.22
Time: 21:05:45
VCDS
Self-Diagnosis Log
Page 7
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AL HW: 1K0 959 703 AL
Component: Tuer-SG 007 2009
Coding: 0000144
Shop #: WSC 00028 028 1012545
VCID: 7AF1EC3135C4789
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AL HW: 1K0 959 704 AL
Coding: 0000144
VCID: 7BFFE9353AFE411
End ---------------------------------------------------------------------
Pourriez vous me dire ce qu'il en ressort ? surtout au niveau du 09-Centr.Electr. ? je ne sais pas ou trouver la signification des codes erreurs ni comment les enlever ou réparer. Si vous pouviez m'aider, je vous en serai très reconnaissant. D'avance merci.
Ps : cette semaine, quand j'ai démarré ma voiture, elle s'est mise à trembler et hop, d'un coup s'est arretée. D'autres jours dans la semaine, les tremblements sont réapparus, de quoi cela peut il venir ?
Encore merci d'avance.
« Réponse #1 le: 07/28/13 »
Tu as un problème de tension trop basse au niveau du démarreur apparemment ...
D'après les codes VW:
A = Batterie
B = Démarreur
C = Alternateur
Pour effacer l'erreur, dans le module central élect, tu click sur clear DTC/ effacer code ... Voir le topic d'AJBe très bien fait sur l'utilisation du vag-com
Hors ligne maxou28
  • Eure et Loir
  • 2.0 TDI 110 BVM
« Réponse #2 le: 07/28/13 »
Merci beaucoup pour ta réponse, je vais la faire charger pendant 12heures et si le problème persiste je changerai la batterie. Merci encore.
