Auteur Sujet: Aide suite a un diagnostic  (Lu 6432 fois)
jay37500
« le: 08/30/11 »
A tous
Je viens de faire un diagnostic sur ma voiture et il me trouve quelques erreurs
Si quelqu un peut m eclaircir sur les differentes erreurs je suis preneur
Merci a vous tous
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 AK    HW: 5K0 907 044 AK
   Component: Climatronic   130 0303
   Revision: 00002001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_Climatronic_VW36.rod
   VCID: 74ECDE8E28E139BC
1 Fault Found
9476885 - Position Sensor for Fresh/Recirculated Flap Motor
             B109B 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 219
                    Mileage: 6985 km
                    Date: 2021.14.16
                    Time: 09:22:23
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 40180A3A98251AC040080000140081E441510088536D8D60648000000000
   Shop #: WSC 00028 028 00001
   VCID: EDDA4BEACBCB6874
   Part No: 1K1 955 119 E
   Component: Wischer 28080  21  0501
   Coding: 009795
   Part No: 1K0 955 559 AH
   Component: RLS 080908 05  54  0402
   Coding: 0330AD
2 Faults Found
00061 - Footwell Lights
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 71
                    Mileage: 8280 km
                    Time Indication: 0
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.45 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
02382 - Sensor for Light Detection (G399)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 61
                    Mileage: 22924 km
                    Time Indication: 0
                    Date: 2028.14.25
                    Time: 17:21:40
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.00 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 250808F1000373
   Coding: E9A07F060002020002
   VCID: 356A238A631B60B4
1 Fault Found
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Mileage: 7689 km
                    Time Indication: 0
                    Date: 2021.14.30
                    Time: 17:32:07
Hors ligne VAG-78
  • 78 proche Mantes la jolie
Re : Aide suite a un diagnostic
« Réponse #1 le: 08/30/11 »
salut,
tu as debrancher l'éclairage au dessus des pieds ?
ton gateway doit etre mal codé, as tu le scan complet ?
VAGCOM 10.6 FR en IDF
jay37500
« Réponse #2 le: 08/30/11 »
non l eclairage n est pas debranché
je te l envoi en mp
golfcara
« Réponse #3 le: 08/30/11 »
Tu as peut etre fait quelque chose a ce niveau(changer d'ampoule ou autre).
golfcara
« Réponse #4 le: 08/30/11 »
A part le capteur de lumiere la plupart de tes défauts sont anciens.
Le gateway a été en érreur a cause de l'éclairage des pieds
Tu as peut etre aussi démonter au niveau de la clim et débrancher son capteur a un moment donné
« Modifié: 08/30/11 par golfcara »
jay37500
« Réponse #5 le: 08/30/11 »
a part mis les leds je n ai rien demonter au niveau des pieds
En tout cas merci de votre aide
golfcara
« Réponse #6 le: 08/31/11 »
Cela peut etre du juste a la faible consommation des leds mais jete tout de meme un oeil a leurs états.
Pour en avoir mis récement sur la plaque d'immatriculation  :argl:
jay37500
Re : Re : Aide suite a un diagnostic
« Réponse #7 le: 08/31/11 »
j ai tout verifié et tout est ok
J ai juste mon ampoule de boite a gant qui est hs
