Auteur Sujet: Erreurs suite passage VCDS  (Lu 7364 fois)
Hors ligne Raven93
  • Seine Saint Denis
« le: 12/14/12 »
Hello à tous,
Ayant investi dans un cable, j'ai passé un diag suite au montage de mon rns pour modifier certaines choses qui n'allaient pas.
Voici ce qu'il en resulte suite aux suppressions d'erreurs:
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Friday,14,December,2012,21:11:24:37412
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 77
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Not registered 0011
56-Radio -- Status: Malfunction 0010
Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 240810F1001636
   Coding: E9A11F0600060200000000
   Shop #: WSC 01357 011 00200
   VCID: EDDB3810F48A616
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Mileage: 29838 km
                    Time Indication: 0
                    Date: 2025.14.25
                    Time: 21:04:56
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 H    HW: 1T0 035 680 H
   Component: RNS-MID       H61 3970
   Revision: AB001001    Serial number: VWZ6Z7M8086008
   Coding: 04000002010000A02011
   Shop #: WSC 05314 123 12345
   ASAM Dataset: ------------------------- ------
   VCID: 336F6E68922E776
2 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 29832 km
                    Time Indication: 0
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 29838 km
                    Time Indication: 0
                    Date: 2025.14.25
                    Time: 21:07:27
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
2 Faults Found:
            000 -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 29832 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 29838 km
                    Time Indication: 0
                    Date: 2025.14.25
                    Time: 21:07:27
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 B    HW: 7P6 035 730 B
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668558644
   Coding: 0A01000000010101
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA_VW36.rod
   VCID: 316364606032456
1 Fault Found:
0022 - Radio
          U1066 00 [000] - No Communication
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000000
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
End   ---------------------------------------------------------------------
Qu'en pensez vous? Et merci d'avance pour votre aide :)
Hors ligne Lesss
  • Gogogadgeto'Golfiste
  • Vroum vroum VROUM ^_^
« Réponse #1 le: 12/14/12 »
As-tu gardé tes anciens codages en copie sur ton ordi ?
Hors ligne Raven93
  • Seine Saint Denis
« Réponse #2 le: 12/14/12 »
Oui oui au cas ou je les ai copié ;)
Hors ligne Lesss
« Réponse #3 le: 12/14/12 »
et en les remettant, même si tu n'as plus les fonctions que tu a rajouté, ton log est plus propre?
Hors ligne Raven93
  • Seine Saint Denis
« Réponse #4 le: 12/14/12 »
J'essaye demain de remettre stock
« Réponse #5 le: 12/14/12 »
Pour la navigation et la radio je vois des différences de longueur dans le codage alors ????
Mais tu ne commencerait pas par déclarer la navigation dans le CAN  :siffle:
En plus les différences de shop, je ne sais pas si c'est à conseiller  :quoi: je crois que j'ai déjà vu des remarques à ce sujet.
« Modifié: 12/14/12 par AJBe »
Hors ligne Lolo78
« Réponse #6 le: 12/15/12 »
et comment tu modifie les shop pour info ?
« Réponse #7 le: 12/15/12 »
C'est visible dans le tuto d'installation du programme, il y a un écran qui montre ces données que Ross-Tech conseille de ne pas modifier. http://www.golf6forum.fr/index.php?topic=12194.msg302607#msg302607
Avertissement Ross-Tech, lire l'intégralité sur leur site: http://www.ross-tech.com/vcds/tour/option_screen.html
Note: If you are an individual user or independent mechanic, just leave the WorkShop Code set to "00000". This allows VCDS to operate in “stealth” mode, keeping whatever WSC that was already in the controller. If you are using VCDS at a Dealership, enter your Dealer's Workshop Code. The Work Shop Code is not easily changed once set on this screen. Contact us for advice if you need to do so.
Some control modules do not allow themselves to be Coded with the default 00000 WSC in place. VCDS should prompt you with a message to input non-zero values in such cases. You should NOT make such changes in the Options screen itself
Maintenant comme apparamment c'est une seconde monte qui a des informations différentes, je n'ai aucune idée de l'effet sur le fonctionnement.
Il faut fouiller dans les nombreux sujet où l'on parle de monter un RNS510, il y est question de ce code shop, WSC etc... par ??? Antares ou ??? Redcbr.
Mais avant tout, Raven93 quand il ajoute un RNS510,
1- il doit déclarer dans le CAN la Radio ET la NAVIGATION, c'est la moindre des choses pour le faire fonctionner,  c'est bien indiqué dans son rapport: 37-Navigation -- Status: Not registered 0011
2- vérifier tous les codages radio et navigation (et éventuellement les autres modules pouvant interférer comme la centrale électrique, le volant multifonctions, l'assistance au parking....) pour qu'ils soient en rapport avec son véhicule et les options installées.
« Modifié: 12/15/12 par AJBe »
Hors ligne seb60
« Réponse #8 le: 12/15/12 »
Il faut rajouter la.navigation dans le.can et supprimer telephone.
faire un raz defaut sur
centrale electrique
radio
navigation
 cela retirera pas mal d erreur.
NE PAS changer les.codes instalateurs workshop !
