Auteur Sujet: Problème diag vcds  (Lu 3756 fois)
Hors ligne Djamco
Problème diag vcds
« le: 03/19/13 »
bonsoir,
j'ai un petit soussi suite à l'activation de mon rns 510 en seconde monte j'ai fait un diag et voila les erreurs
VCDS Version: Release 11.11.0
Data version: 20111111
Tuesday,19,March,2013,17:37:41:37412
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ13ZBV035767
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 AQ    HW: 03L 907 309 R
   Component: R4 2,0L EDC   H23 6780
   Revision: 42H23---    Serial number:
   Coding: 001D0012042400080000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ECM20TDI01103L906018AQ 003007
   ROD: EV_ECM20TDI01103L906018AQ.rod
   VCID: 79F39C40F8C24D6
1 Fault Found:
4629 - ECM Power Relay Load Circuit: (J271)
          P068A 00 [032] - De-Energized Performance Too Early
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2602
   Revision: 05351112    Serial number: 00001102271552
   Coding: 0000020
   Shop #: WSC 00020 790 00000
   VCID: 1D3BA8D0C4AAD16
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 743B40F5492500FF2E1202EA92200042350800
   Shop #: WSC 00020 790 12345
   VCID: 76E9977CC1DC22E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW36.rod
   VCID: 800571A41B189CE
Address 09: Cent. Elect.        Labels: None
   VCID: 55ABF0F0BC1A496
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D03HJSB
   Coding: 0012359
   VCID: 6FE7A2187E86136
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110316301017
   Coding: 1892140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWSXS_VW36.rod
   VCID: 7EF98F5CE1EC6AE
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H06 0010
   Coding: 830000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1K8 920 872 A    HW: 1K8 920 872 A
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 170B01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
   VCID: 316364606032456
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 270311F6002170
   Coding: 354000
   VCID: 3065616463384CE
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
   VCID: EAD1330C0D6476E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 P    HW: 1T0 035 680 P
   Component: RNS-MID       H70 5218
   Revision: AB001001    Serial number: VWZ6Z7Z5605656
   Coding: 06000442000000802000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: ------------------------- ------
   VCID: 3B7F4648BA7EBF6
   Subsystem 1 - Part No: 1T0 919 859 B
   Component: EU West V8  7672
4 Faults Found:
02873 - Control Module for Back-Up Camera (J772)
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 5
                    Fault Frequency: 15
                    Reset counter: 80
                    Mileage: 27712 km
                    Time Indication: 0
00857 - CD Changer Unit (R41)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 5
                    Fault Frequency: 8
                    Reset counter: 42
                    Mileage: 29512 km
                    Time Indication: 0
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 28325 km
                    Time Indication: 0
                    Date: 2022.14.02
                    Time: 15:46:41
01523 - Microphone for Telephone (R38)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 88
                    Reset counter: 42
                    Mileage: 27719 km
                    Time Indication: 0
                    Date: 2021.14.26
                    Time: 11:23:14
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2129
   Coding: 0016437
   VCID: 39735C4070428D6
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 346D6D74572070E
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0016436
   VCID: 3A71434C754486E
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 15
                    Reset counter: 80
                    Mileage: 27712 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 8
                    Reset counter: 42
                    Mileage: 29512 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 21
                    Mileage: 28325 km
                    Time Indication: 0
                    Date: 2022.14.02
                    Time: 15:46:41
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 88
                    Reset counter: 42
                    Mileage: 27719 km
                    Time Indication: 0
                    Date: 2021.14.26
                    Time: 11:23:14
End   ---------------------------------------------------------------------
Hors ligne Lesss
  • Gogogadgeto'Golfiste
  • Vroum vroum VROUM ^_^
Problème diag vcds
« Réponse #1 le: 03/19/13 »
Tu as le bluetooth? caméra de recul,...?
Hors ligne Djamco
Problème diag vcds
« Réponse #2 le: 03/19/13 »
non je n'ai aucun des deux pour le moment,
ils sont tout les deux dans les cartons ^^
que dois-je faire pour palier a ces erreurs??
Hors ligne Lesss
Problème diag vcds
« Réponse #3 le: 03/19/13 »
Il semble qu'ils soient activés, à tort dans le RNS, peux-tu communiquer avec le RNS pour désactiver tous ça? sert toi des nombreux tutos du forum pour ne pas mettre n'importe-quoi dans le codage....  :ange:
